When dropping the gas tank ?
Old 01-29-2009, 05:26 PM
TAZ454's Avatar
TAZ454 is an unknown quantity at this point
Default When dropping the gas tank ?
Is there enough slack on the hoses and lines ?? How far can the tank go down before you have to dissconnect a line or connection ??
Old 01-29-2009, 07:44 PM
WolfPack's Avatar
Default RE: When dropping the gas tank ?
about 3'?
Not far at all. you'll snap something on the fuel pump, a vent tube, or pull a ground strap. What are you trying to do exactly?
Old 01-29-2009, 08:30 PM
TAZ454's Avatar
ORIGINAL: WolfPack
about 3'?
check out for vacuum leaks bad connections kinked lines, had fuel pump replaced , after 150 miles iam getting a po442 error code
Old 01-31-2009, 01:52 AM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
defiantly Lower tank with loving care! That trouble code is most like that roll over valve in the front of the tank. i have the same code )
swizznuker
15
10-10-2012 07:59 PM
ff_malone
01-04-2010 02:26 AM
authoriti29
10-20-2009 11:13 AM
TAZ454
02-16-2009 09:52 AM
ShaneInsane
12-12-2007 09:08 PM
Quick Reply: When dropping the gas tank ?
