How to tell if front wheel bearings are bad ? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 09-16-2005, 07:39 PM
yzf125 is an unknown quantity at this point
Default How to tell if front wheel bearings are bad ?
How do you know if your front wheel bearings are starting to go ?? I am asking because i had a front end shake ( Like a wheel out of balance ) So i had the front wheels balanced and i still have the problem. It is there all the time and some times not as bad, Thanks for any help.
Old 09-16-2005, 09:05 PM
Joshua M. Smith is an unknown quantity at this point
Default RE: How to tell if front wheel bearings are bad ?
Hello,
Check the tierod ends first for excessive play (and you'll know if it's excessive).
They control the steering so you really don't want to let it go too awful long.
Josh <><
Old 09-17-2005, 11:56 AM
Paddle_grl's Avatar
Paddle_grl has a spectacular aura aboutPaddle_grl has a spectacular aura about
my driver's side front bearing is going bad..I have known it for a while..started out as an intermittent vibration...got more steady and is starting to be noisey..not grinding yet..(hopeing to replace it soon) this will be my second wheel bearing gone bad..so I guess is it just shaking, or making noise?
Karin
Old 09-17-2005, 05:25 PM
One way to see if there is play is to jack up only the side you are inspecting (so that only that wheel is off the ground). By putting your hands at 3 & 9 o'clock on the wheel, see if you can feel play. If you can, this is most likely the tie rod end (but could be the tie rod end on either side). When you put your hands at 12 & 6 o'clock on the wheel and check for movement, this would be your wheel bearings and/or ball joints (wheel bearings being the more prevalent cause of this type of play). If the vehicle is 2wd, you can further 'feel' for problems by spinning the wheel and feeling for 'grittyness'.
Old 09-17-2005, 11:45 PM
Thanks for the help !!!!!
Closed Thread
Thread Thread Starter Forum Replies Last Post
Wheel Bearing noise.... It isn't the wheel bearings(?) ComputerNerdBD Steering, Suspension & Drivetrain 4 08-30-2011 10:59 PM
Wheel bearing noise that is not coming from wheel bearings ComputerNerdBD Tires and Wheels 0 03-05-2011 05:50 PM
95 S10 4x4 front wheel bearings flat lands blazer 2nd Gen S-series (1995-2005) Tech 2 07-30-2010 09:21 PM
K5 Front wheel bearings ? EnyChevyUK Full Size K5 Tech 5 03-21-2009 07:55 PM
Bad Wheel Bearings, but maybe not???? gERgMan 2nd Gen S-series (1995-2005) Tech 6 05-15-2008 08:19 AM
Tags
2002, bad, bearing, bearings, blazer, blazerforum, chevy, ends, front, left, long, rod, run, tie, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
