ignition
ignition
OK here's the story.
I bought a 96 blazer that needed head gaskets, put everything back together, charged the battery over night, changed the oil, filled the coolant, etc.
new ignition(coil, ICM, Cap, rotor, wires) and I'm getting a weak spark from the wires , tested spark from coil=strong,
tested spark from plug wires=weak and almost non-existent
Any ideas?
Any ideas?
Yah, the same part was listed under both the pick-up coil and crank sensor.
Now it won't start with the Mass Airflow Sensor plugged in and there is a knock that has turned out to be a bent rod, probably from the pressure of the coolant that was in the cylinder on top of the piston....uggghh
When I bought it, it seemed like a good deal, $1,000 with only 154,000 miles on it and all it needed was a head gasket. Well, I tear it down and both intake manifold gaskets leaked and there was coolant in the #5 and #6 cylinders. Now about $250 later after gaskets of all sorts, new ignition parts oil, coolant, plugs and now new push rods I'm starting to think not such a good deal.
Just frustrated, thanks for listening.
That would be the cam sensor. The crank sensor is located at the front bottom of the engine.
Yup, camshaft position sensor is in the distributor, and it can not cause a no start condition, (the engine will start and run with the sensor disconnected). After replacing the sensor, camshaft retard must be checked/adjusted using a capable scan tool.
Brian5792
10-24-2018 11:34 AM
trettifire
10-03-2009 08:48 PM
RichieTwo
08-12-2005 11:30 PM
