Ignition stuck in on position
Old 04-23-2012, 09:39 PM
Tan99Blazer's Avatar
Tan99Blazer is on a distinguished road
Default Ignition stuck in on position
I noticed about a week ago when I crank my blazer the ignition felt like it was sticking a little before it clicked back after starting. Today I went to start it and it got stuck in the on position and I couldn't turn it off so I had to unhook the battery. Anyone have any ideas on what's happened? Thanks. Also is it safe to spray a small amount of wd40 in the key slot? Don't figure it will work though. I also stuck a screwdriver inside the hole under the steering column but it never released the ignition.
Old 04-24-2012, 08:41 AM
spittybays
Guest
Posts: n/a
Wd should be fine. Your getting looks but no one yet really has an answer. This kind of stuff happens with alot of steering columns. Spray it, turn the wheel, jiggle it. That kind of stuff. When it does go back try to remember what you you did.
marezf01
03-19-2015 12:36 PM
mcmastrman
07-26-2012 06:27 PM
robbh432
06-20-2012 08:55 PM
Tan99Blazer
04-23-2012 09:22 PM
ride_da_lightnin
19
04-20-2008 10:36 PM
Quick Reply: Ignition stuck in on position
