Leaking Oil Cooler Hose and Oil Filter O-Ring
Old 02-03-2008, 04:47 PM
shooter2499's Avatar
shooter2499 is an unknown quantity at this point
Default Leaking Oil Cooler Hose and Oil Filter O-Ring
I had some work done on my 2000 2WD blazer recently and the dealer told me I have a leaky oil cooler hose and oil filter o-ring. They wanted to charge me $450 to replace....yeah right. Can any one help me out with how to go about this?
Thanks, Tyler
Old 02-03-2008, 10:20 PM
Default RE: Leaking Oil Cooler Hose and Oil Filter O-Ring
Check this out: HOW-TO: Leaking Remote Oil Filter Lines
Old 02-04-2008, 07:31 PM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
Good luck with that, me and dad were gonna fix mine, but we got to looking at it and there was a couple bolts that we couldnt get to and ended up just taking itto a garage.
Old 02-04-2008, 09:23 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
2wd is REALLY easy as compared to 4wd though!! Just one set of lines and no front diff in the way!! Tyler, you should be able to have that job done in under 2 hours working on the ground! I think the last one I did, which I do them all the time, took me about 25 minutes, so with no experience it will still be a quick job!! Good luck!!
latunguley
11-17-2014 09:15 PM
86TransAm
14
12-13-2011 07:46 PM
fslobodecki@yahoo.com
04-15-2011 03:29 PM
alesv
04-12-2010 11:21 AM
Jetfixer
07-11-2006 05:02 AM
Quick Reply: Leaking Oil Cooler Hose and Oil Filter O-Ring
