pwr door lock relay
pwr door lock relay
I have 95 4 dr. all 4 power door locks and tail gate not working ,fuse good ,not getting pwr. to switch.have a haynes manual.suspect problem in wire between and switch fuse would like to know where relay is .can't here it clicking.have switched the two in the glove compartment. no difference any info would be appreciated
thanks J.C.
thanks J.C.
RE: pwr door lock relay
Look at the sticker on the underside of the lid for the under the hood fuse/power distribution block. Then I would try removing it and then reinstalling it, maybe this will work maybe not, you may have to try a new replacement relay, or check to make sure all the wires are connected properly.
ExplicitYourSelf
06-24-2010 07:28 PM
dardamar
10-08-2008 02:03 AM
