lights STILL flickering
ok so ive checked my battery connections and cleaned the terminals, checked the wires on the alt and checked my headlight connections (the wire to make my halo's light up) and ive gone to the parts store to have the check my battery and alternator and they say everything is working just fine so if everything seems fine why are the lights still flickering im open to any and all suggestions thanks guys.
RE: lights STILL flickering
and the volt meter in the truck is reading anywhere from half way (14vlots) to about 2 lines past that if that helps at all
anyone?? any ideas?
I had that same problem. it turned out to be my altenator!!! It was 100$ to change it, did it myself in 10 minutes..solved the problem... too bad ya werent in NY i`d swap it out for ya..
well maybe ill just have to pick a new one up to see it that takes care of itlol 10mins is pretty quick tho my best time is about mins
Try the new alt and do the big three upgrade.
any news on the flickering headlights?????????????
RIFLEMAN 308
11-12-2020 06:30 PM
Numba1Sean
17
11-16-2008 06:59 PM
