Lost my heater controls to a bad transfer case switch! - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-26-2012, 01:59 PM
ESKYMOPACK is an unknown quantity at this point
Default Lost my heater controls to a bad transfer case switch!
1995 GMC JIMMY S-Series 4.3 vortec auto 260,000 and still tickin'.
The 3 prong 4x4 switch on my transfer case took a dump and allowed trans. fluid to get into all my vacuum lines, which must have ruined my actuators in my heat controls, along with the 4x4 actuator under my battery. No matter what position i put the control on, it blows heat through the defrost and the floor evenly I guess. Once the problem was diagnosed, I sprayed electrical cleaner into the vacuum system but it did not fix the problem. I thought I had read this B4, but can't remember the remedy. Can anyone give a helpful hand??
ESKY
Old 01-27-2012, 07:34 AM
spittybays
Guest
Posts: n/a
I have read you need to blow the lines out with compressed air but I don't know the sequence. Top to bottom makes sense. I would take the three line connector off the switch. Then start with the top like vacum reservoir, actuator, ect. The thing is you will need to applie the compressed air after the vent T's. You might be able to rig a little nipple on the tube of canned air. I do that cause no compressor.
Old 01-27-2012, 09:19 AM
Vahomboy is on a distinguished road
Heater control needs to be replaced after you made sure you've cleaned all the lines of trans fluid. The fluid has ruined the rubber diaphram in the selector switch and most likely the culprit now. Be sure the to clean the lines first because I found out the hard way.
Old 01-27-2012, 11:04 AM
Thanks guys. But I already changed the controls....they weren't corrupted with fluid, but where I think the problem lies is in the vacuum diaphram. I think the trans fluid got in there and ruined the rubber diaphram (so I'm thinking) and won't open the lever. I think it was Swartlk that metioned in a thread B4 that it (lever) would automatically go into a mode between both the floor and the defrost, and that's what I think I've got.
If that's the case, how hard is it to get to that vacuum diaphram to replace it. When I shut off the blower, I can hear a vacuum hiss down somewhere under my dash which I'm assuming is that diaphram, because I don't think getting trans. fluid in the system will eat up the rubber lines as much as kill a vac. diaphram, do you??
Old 01-27-2012, 03:52 PM
spittybays
Guest
Posts: n/a
GMC Sonoma & Chevy S-10 Transfer Case Vacuum Switch This guy did kind of a nice job on this, hope you can get to it.
Old 01-31-2012, 11:39 AM
Thanks, Spittybays. I do not look foward to the job, but it's going to have to get done, along with a heater core!
Old 02-02-2012, 08:14 AM
Sulley is on a distinguished road
I have a 98 Blazer with AC and my Temperature controll does not work, it stays on high heat all the time, is there a relay for it. Thanks for any help. Sulley
Old 02-03-2012, 01:51 PM
spittybays
Guest
Posts: n/a
Sulley, you need to start a new ? thread with a title and your info cause no one will see it on the bottom of someones old thread.
Old 02-04-2012, 08:15 AM
OK thanks. Sulley
Closed Thread
Thread Thread Starter Forum Replies Last Post
Will a transmission np236(4 button) transfer case fit np233 (3 button) transfer case Flyfishen Engine & Transmission 3 01-24-2014 07:27 PM
Heater Controls cbenslay GMT 360/370 Tech 3 12-29-2010 06:45 AM
ac and heater controls harley Full Size K5 Tech 1 01-22-2009 07:42 AM
Changing Light Bulbs Behind Heater Controls? bluesjam99 General Chat 2 02-17-2007 03:34 AM
a/c heater controls don't work mrbill531 General Tech Help 2 09-12-2006 12:56 AM
Tags
1995, 98, bad, blazer, case, chevy, controls, doesnt, heat, heater, relay, s10, switch, transfer, transfercase, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
