RE; Air Noise
Old 04-17-2010, 06:12 AM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Smile RE; Air Noise
at highway speeds i am hearing loud air noises on the driver's side window on top. i put my hand by the weatherstripping applying a little pressure and the noise lessens. when i look at the weatherstriipping she looks good and solid.
any suggestions or have you experienced the same.
Old 04-17-2010, 02:20 PM
1998MSO's Avatar
1998MSO is on a distinguished road
What year, model etc....? I had a similar issue with my 98. The door hinge pins caused the door to sag slightly. Worn hinge pins and bushings seem to be a common issue.
Old 04-17-2010, 04:12 PM
Smile RE; Air Noise
she is a 2002 4 door blazer
Thanks.................................
Old 04-17-2010, 06:09 PM
ff_holt1's Avatar
ff_holt1 is on a distinguished road
my 99 makes that noise to i just never really looked to see what was causing it...
Old 04-17-2010, 11:31 PM
Most likely cause is failed hinge bushings.
When you close your door, does the door jump up as it latches onto the nader bolt (latch pin in the 'B' post)? Is the top of the nader bolt scored or worn?
Old 04-18-2010, 05:57 AM
Cool Re Air Noise
I will ask my buddy to check it out.
Old 04-18-2010, 07:43 AM
KRUSHER's Avatar
KRUSHER is on a distinguished road
My 2001 does the same thing. It needs door bushings as well. My door got to making noise when it shut and I discovered this crack:
Luckily I got a buddy at work to TIG weld it back up for me.
moboys
08-01-2011 08:26 PM
nuwave
02-10-2011 01:28 PM
jojocarreno
07-01-2010 07:30 PM
dimmuborgir6nik6
10-02-2008 06:51 AM
Quick Reply: RE; Air Noise
