Low Speed (Below 5 MPH) ABS Activation
Is there anyone who has managed to clean the ABS sensors to avoid a "Low Speed (Below 5 MPH) ABS Activation" or just buy new ones at once?
Another Tech Article (DIY) section bump.
I've cleaned several, but have had to replace a few due to the wires being broken off too close to the sensor itself to allow for a wiring repair.
Is there any way to check the ABS brakes by OBD2 so i can se whitch corner is broken, I use Tourque / bluetooth on my android but it can not check the ABS. I guess the shops have better diagnostic tools but still use OBD2 anyway?
http://www.amazon.com/Actron-CP9449-...5508604&sr=1-7
The ABS system is not included in generic OBD2 data. You need to use a scan tool with enhanced capability for GM vehicles to access the ABS system.
the ABS sensors on a 98 blazer are only on the front hubs right? or is there one on the rear end?
Pipewrench Dale
11-10-2014 06:16 PM
Clay_Assassin
12-12-2010 08:04 PM
Brianator99
10-27-2010 09:09 AM
