Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Gen S-series (1995-2005) Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Blazer Forum!
Welcome to Blazer Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Blazer Forum today!
Reply
LinkBack Thread Tools Search this Thread
Old 04-11-2010, 10:54 PM
2000 Chevrolet Blazer
leeroy74 is on a distinguished road
Default Missing PVC valve!
Bought a new PVC valve to do a tune up and it was missing... The plastic tube from the air intake was connected directly into the crankcase cover with no pvc valve. I put the pvc valve in but the plastic tube is missing a connector or flexible rubber tubing so I can connect the hard plastic tube to the pvc valve. Is this okay or will it put oil in the intake manifold?
2000 Blazer 4.3L 4x4 152,000 miles
Old 04-12-2010, 12:57 AM
TireGrit's Avatar
Location: Hanover County, VA..Mechanicsville to be exact.
TireGrit is on a distinguished road
Leeroy, On mine, looks like about a 3 inch section of vacuum hose with an inner diameter large eough to fit snuggly around the top of the PVC valve which will also accomadate the connection of the plastic tube at the top. Make sure both fit securely with no vac leaks. I would just get this small section of hose from your local parts store and give it a shot.
Old 04-12-2010, 08:32 AM
RonJon is an unknown quantity at this point
You're looking at the wrong side of the motor. PCV valve is on the drivers side. That Plastic tube is a fresh air intake for the motor, the PCV draws across the motor and is connected to the intake manifold on the drivers side.
__________________
2000LT Blazer 4x4
Old 09-07-2010, 07:54 PM
bill737's Avatar
bill737 is on a distinguished road
Is there a chance someone could post an actual photo of where the PCV valve is? I've read every thread on the forum with the tag "pcv" and while it's location is "explained", I still can't find it...(I'm not all that smart.) I searched the interweb as well, but no good photo, video, or schematic that I understand for Blazers or Jimmys.
I have a 2000 ZR2 and was just kind of looking for it to see if it needs cleaned or replaced - and for future reference. A photo, maybe with an arrow pointing to it sure would help rookies like me!
Thanks so much in advance!
__________________
Black 2000 ZR2
Old 09-07-2010, 08:19 PM
bill737's Avatar
Swartlkk, you know I actually printed that very same schematic out from one of your other postings and I still can't find the damned thing. Is it buried and out of sight, or should I be seeing it up top on the driver side?
I'm sorry for such a dumb question, but I am quite literally as "green" as it gets when it comes to this stuff - but I am reading a lot and trying to get better!
__________________
Black 2000 ZR2
Old 09-07-2010, 08:27 PM
1974 Chevrolet K Blazer
My Garage
Send a message via ICQ to swartlkk Send a message via AIM to swartlkk
Item #8 in that image is the PCV valve. It is located in the left hand valve cover directly above the 'VORTEC' embossed on the valve cover.
Old 09-07-2010, 08:34 PM
bill737's Avatar
Thank you sir; I will check that out again tomorrow. If I may ask one last moronic question - when I look at an engine schematic like that one, and see the big master arrow (which I believe indicates the front of the engine), is that pointing toward the headlights?
__________________
Black 2000 ZR2
Old 09-07-2010, 08:45 PM
My Garage
The large arrow always points to the front of the vehicle.
Old 09-07-2010, 09:52 PM
rriddle3's Avatar
2012 Ford Mustang
Just FYI, bill737, anytime 'right' or 'left' is mentioned, it's referring to the position as viewed from the driver's seat. As in the air filter is on the 'left' and the battery is on the 'right'.
Reply
Tags
2000, 2002, 98, blazer, chev, chevrolet, hose, locating, location, missing, pcv, picture, pvc, side, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
