My 1995 Blazer 4.3L Vortec,Rough Idle and Burning Rich
Old 09-18-2009, 04:31 PM
jp's95Blazer's Avatar
jp's95Blazer is on a distinguished road
Default My 1995 Blazer 4.3L Vortec,Rough Idle and Burning Rich
Hello All. Im a new user on here. Any help is very much appreciated. My 1995 Chevy Blazer with a 4.3L Vortec in it, is Idling very rough and burns extremely rich, you can smell it! Idle's rough when cold, but idle's even worse when warmed up. Im after replacing recently, Map Sensor, 02 sensor's, rotor cap,plugs and plug wire's, cadlatic converter,don't think I spelled that right. EGR Valve, Im sure I am forgetting other parts I have replaced. Like I say it burns really rich, and you can see the black on the tail pipe. This is me and my wifes daily driver and only vehicle. I really need to get this thing fixed, I dont want to junk it, Its near mint shape inside and out,would be a shame. Oh yes, the other day I had it at a mechanic shop and on the scanner, and it say's engine misfire, and burning rich. Thats all it said. Any help here would be so much appreciated. Thanks alot,John.
Old 09-19-2009, 03:29 PM
1995LS is on a distinguished road
Hey sorry for your truck luck,i have the same prob no misfire fresh tune up, fuel filter.no power til 3rd gear kicks in then its a rocket lets help each other
Old 09-19-2009, 05:46 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
What kind of spark plugs do you have on there? Do you have a Check Engine Light on? Have you had any problems with your Oxygen Sensors?
Old 09-20-2009, 12:31 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
have you pulled your manifold tuning valve to check the FPR for a leak? if its leaking it will cause that too. look inside for fuel puddling....i found some in my 95.....so now im gonna replace the entire spider....
Old 09-28-2009, 11:57 PM
doc4663's Avatar
doc4663 is on a distinguished road
Had same issue with my 95 i had to replace my intake manifold gasket passager side was in three pieces
Old 10-04-2009, 10:22 AM
was it the original intake gasket? or had they been replaced before? and where did you buy the new replacement gaskets from? thanks
Mcguire1205
04-19-2013 05:11 AM
David Doval
07-22-2012 04:05 PM
sweezo
19
07-14-2011 11:06 PM
cochran07
12-01-2010 10:33 PM
cakt
12-29-2008 04:01 PM
Quick Reply: My 1995 Blazer 4.3L Vortec,Rough Idle and Burning Rich
