need help p1345 code
Old 03-24-2013, 05:35 PM
bakalo0323's Avatar
bakalo0323 is on a distinguished road
ok so when i line up the marks on balancer the intake valve (second from the front) is open. It is not supposed to be is it? Also if i am turning the crank and feeling for air to come out the plug, the marks arent close when i feel the air
  #32
Old 03-24-2013, 06:21 PM
Nope. When the marks are lined up, both valves must be closed.
  #33
Old 03-24-2013, 06:30 PM
bakalo0323's Avatar
After i feel the air come out of the plug hole how far should i have to turn the crank before it at tdc?
  #34
Old 03-24-2013, 06:34 PM
It depends how close you "time" releasing the starter after you feel/hear the stronger burst of air. If you have the driver side rocker arm cover off, do it as described in post #30. If you do it like that, you KNOW it's correct.
  #35
Old 03-24-2013, 06:45 PM
bakalo0323's Avatar
Ive tried doing it like in post #30. Liked i said when i line the marks up the intake valve is open. I am turning the crank by hand and waiting for the air to push my finger off. I thought i might be able to get it close to tdc that way since the marks are no help to me since they are off.
  #36
Old 03-24-2013, 08:45 PM
Don't pay attention to the push of air, it's gonna mess you up When the piston is at TDC and the intake valve is open, the cylinder just completed the exhaust stroke and is starting the intake stroke. Rotate the crankshaft one revolution clockwise and line up the timing marks. Both valves should be closed.
Klturi421
09-25-2012 08:13 PM
dirty420
05-29-2011 10:15 AM
b77dougan
Engine & Internal
07-27-2010 06:52 PM
4x4willywill
12-23-2007 04:33 PM
Mr Blazer LT
01-17-2007 11:25 PM
Quick Reply: need help p1345 code
