Need help w/ Bleeding Brakes
What's the procedure for bleeding brakes and MC for a 1998 Blazer 4WD? I think my partner in crime let the MC run low when bleeding it and introduced air. I thought we had the correct procedure, but now I'm not so sure - after lots of work trying to bleed air out of the MC, the brake pedal is still mushy when testing.
Help!
Help!
RE: Need help w/ Bleeding Brakes
start with the furthist wheel away from master, Pass. rear, then the next closest, driver rear, then the next, pass. fron, then the driver front. keep checking the master af the fluid level and fill it up as needed
Thanks! (I found one of Kyle's posts for dealing with the MC elsewhere, but it seems like the same procedure works just fine.) The Blazer brakes fine after a test drive now.
I knew I had wrote something to this affect up at some point! LOL Glad you got it all figured out and fixed up!!
mikede123
09-20-2011 11:32 AM
upmaine
08-28-2010 07:56 PM
toaks1
16
01-20-2010 08:12 AM
flamez2647
07-28-2009 09:40 PM
