No 4wd, no light - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 02-01-2009, 08:47 PM
mikeymo67 is an unknown quantity at this point
Default No 4wd, no light
My 4wd system is not working. There are no lights on the buttons at all. I've checked the fuses and that thing in the passenger side kick panel. I tried disconnecting the battery. Any ideas on what the problem could be? Could it be the switch itself?
Old 02-03-2009, 05:59 PM
Ericthemidget is an unknown quantity at this point
Default RE: No 4wd, no light
Feel for ya. Mine did the same, but will not go into any gear. Tried to shift into 4lo, it made a couple grinding noises, service 4wd light came on, now nothing. No lights, transfer case stuck in neutral. Fuses are not blown, worked fine all day in 4hi, and 2wd, then quit right in front of the house. If any one has any ideas, I sure could use some help.
Old 02-03-2009, 08:07 PM
Mine works in 2wd. It just won't go into 4wd. It's not a big problem unless there is unexpected snow. I usually drive my Tracker when it snows. The Blazer doesn't handle the slippery stuff as well.
Old 02-04-2009, 07:07 AM
Many, MANY posts on this issue. You have to start by telling us what 4wd system you have... 3-button (NV233) or 4-button (NV236)...?
And to Ericthemidget, you can certainly read along in this thread, but if you must ask questions, please do so in a thread of your own so this thread does not take an unexpected twist towards your problem and maybe away from the problem that mikeymo67 is experiencing.
Old 02-05-2009, 06:07 PM
I have the system with four buttons.
Closed Thread
Thread Thread Starter Forum Replies Last Post
1985 4wd light not coming on doesnt feel like its in 4wd justblazin1 1st Gen S-series (1983-1994) Tech 1 10-19-2014 11:12 AM
4wd-ABS-service 4wd light.info need please parks336 2nd Gen S-series (1995-2005) Tech 11 10-25-2013 03:58 AM
99 - multiple issues - brakes, front end, Serv 4wd light, rough running, airbag light Jonboy 2nd Gen S-series (1995-2005) Tech 12 03-12-2012 07:08 PM
4WD HI light only flashes, but 4WD works. scrawford 2nd Gen S-series (1995-2005) Tech 1 12-29-2009 05:51 AM
4wd light flashes but no 4wd LJ809 Steering, Suspension & Drivetrain 4 11-25-2009 08:43 AM
Tags
1984, 1993, 1999, 4wd, 4x4, blazer, button, chevy, drive, fwd, lights, systems, troubleshooting, wheel, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
