Any idea how to fix this door latch metal?
Old 06-11-2012, 06:01 PM
jimi's Avatar
jimi is on a distinguished road
Default Any idea how to fix this door latch metal?
Here is a picture:
It's basically broken through all around the latch, and only held on by a little metal on the outside and some paint. I can wiggle it easily, and the door doesn't really close well obviously. I'm actually amazed it's still holding on.
Anyone had a latch do this?
Old 06-11-2012, 07:14 PM
NVANZEE's Avatar
it is caused by you door pins and bushings being bad for a LONG time. You will have to pull it off and weld in a piece of steel to fix the striker. You may also need new door hinges as im sure the pins have worn into them or drill the holes and get oversized bushings
Old 06-11-2012, 07:35 PM
Spot on perfect, I agree 100%. If you keep them lubed & replace the pins & bushings at the first sign of wear, that'll never happen.
Old 06-12-2012, 06:27 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Not entirely true. Ive stayed on top of my pins and bushings. Once the cracking starts, it will continue no matter what your pins and bushings look like. The holes in my hinge are still in perfect shape, yet my door latch looks the same. I change them out at any sign of misalignment of door and jamb. I also constantly check my bushings to make sure they aren't cracked.
Old 06-12-2012, 12:02 PM
Misalignment of the door is what gets the process started, worn pins and or bushings, (or an accident) is what causes the misalignment.
ComputerNerdBD
02-29-2012 08:09 PM
blazinloud
24
10-01-2011 05:33 PM
ussexplorer
08-10-2011 12:14 PM
cjh
05-15-2010 09:06 PM
ESKYMOPACK
14
03-27-2009 09:42 AM
Quick Reply: Any idea how to fix this door latch metal?
