No power to OBD II scanner
Old 01-17-2010, 12:26 PM
bbr's Avatar
bbr
bbr is offline
bbr is on a distinguished road
Default No power to OBD II scanner
I tried to read the codes on a 99 Blazer, but the scanner didn't power up. It's not the scanner because it worked on another '00 Blazer. I probed pins #5 & #16 on the vehicle side & didn't get any voltage. This is with the key in the run position. I tried cycling the key a couple of times.
Does anybody have a schematic for the OBD <-> BCM interface, so I can start debugging this further?
Thanks
Old 01-17-2010, 01:31 PM
rriddle3's Avatar
IIRC, it's powered by the same fuse as the cig lighter. Have you checked that one?
Old 01-17-2010, 03:27 PM
bbr's Avatar
bbr
bbr is offline
Thanks. We got the code pulled.
Old 01-17-2010, 03:52 PM
rriddle3's Avatar
That's good, but what was the solution?
Old 01-17-2010, 05:13 PM
bbr's Avatar
bbr
bbr is offline
Blown cigarette lighter fuse.
klote82
16
10-10-2018 06:22 PM
Little Roober
12-30-2012 10:43 AM
Blazer_LT
11-06-2011 06:03 PM
dkk1661
03-29-2011 08:25 PM
blazer#3
TrailBlazer GMT360/GMT370 (2002-2009) Tech
05-25-2009 05:56 PM
Quick Reply: No power to OBD II scanner
