noise coming from right front while driving in 2 wheel dr...
Old 01-28-2012, 08:13 PM
chad911's Avatar
chad911 is on a distinguished road
Default noise coming from right front while driving in 2 wheel dr...
Can anybody help me out?? I have a 2004 blazer and as i was getting off the expressway, I heard a very loud whining noise coming from the right front side... When i put it in 4 hi it goes away.... Any suggestions??? I checked the vacuum hoses from the transfer case and they seem to be connected ... Maybe the switch????
Old 01-29-2012, 03:40 PM
DKSDAD's Avatar
I have a simillar noise I am trying to diagnos. If I come up with anything I will put it up.
Old 01-29-2012, 05:57 PM
02fbody35th's Avatar
02fbody35th is on a distinguished road
Same here. It's like a whining noise almost like a hub bearing or u joint but it is non existent in 4 high. And it's only at higher speeds that you hear/feel it
Old 01-29-2012, 06:58 PM
onder's Avatar
onder is on a distinguished road
Does it go away when you turn your wheels right or left?
Old 01-29-2012, 07:01 PM
Mine doesn't
Old 01-30-2012, 08:06 AM
chad911's Avatar
it goes away when you put it in 4 wheel drive... i worked on it all weekend trying to figure it out... i chased down vacuum lines coming off the transfer case... i did everything short of tearing the differential apart and changing the switch on the transfer case... i had an abs light flash on and off then took it for a ride and the sound is gone... i have no idea what it is..
Old 01-30-2012, 04:57 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
Sounds like you have a faulty transfer case vacuum switch. Is this a 3 button 4wd unit ?
Old 01-31-2012, 07:54 AM
chad911's Avatar
the switch?? figures... i was gonna change it but some of my firends were telling me that the switch wasn't the problem.... i will check into that... thx
Old 01-31-2012, 04:31 PM
jck1961's Avatar
I wasn't referring to the switch on the dash. This switch is on the top of the transfer case above where the front driveshaft is. It has 3 vacuum lines that attach to it. This is assuming that your blazer has a 3 button 4wd set up.
Old 01-31-2012, 09:35 PM
How hard is it to change that vacuum switch. Any tips and tricks would be appreciated. It looks pretty hard to get at
Quick Reply: noise coming from right front while driving in 2 wheel dr...
