I can smell gas around the fuel pump
Old 03-20-2012, 04:58 PM
MakaveIi's Avatar
MakaveIi is on a distinguished road
Default I can smell gas around the fuel pump
I had my fuel pump replaced in September of 2009, and it seemed fine ever since, but now that it's been really hot I've used my A/C and yesterday I noticed my fuel pump was awfully loud, so I got out and fuel can be smelled just by opening the door. The smell is coming from the fuel pump, and it's only while the car is hot so far. It sounds like it's continuously priming while the car is running, once again, only while it's hot. If I turn the car off while the smell is there, the scent goes away immediately, and there aren't any visible leaks. I'm not sure if it could be related to me using the A/C, I don't see how it would be, but it just started since I've been using it. This doesn't seem good so any insight would be appreciated. I've also had a P0446 code pop up lately.
Old 03-20-2012, 05:44 PM
step66's Avatar
All sorts of issues can cause this after a pump change,most likely a venting hose or fitting was broken during re-assembly-very common! Search this site and you will have all the leads to remedy this issue;It may mean dropping the tank again so drive it till its almost empty.The codes are described here as well and if I recall that may be the EVAP code. Don't even smoke around this car until it is fixed!
Old 03-20-2012, 05:49 PM
pettyfog's Avatar
I think you may have more than one problem.
Do you recall the tank having a lot of pressure last time you took off the cap?
Old 03-20-2012, 08:09 PM
The P0446 is indicating a problem with the vent solenoid or its circuits and could be the cause of the fuel odor. Another possibility could be a leaky O ring for the fuel pump module. Aftermarket fuel pump modules frequently have the wrong size O ring, and they leak, causing a fuel odor and EVAP DTC's to be set. Follow the flow chart in this link: https://blazerforum.com/forum/diagno...plained-35143/
Old 03-21-2012, 08:56 AM
MakaveIi's Avatar
Not that I recall, but I haven't filled up since I noticed the problem, so I never payed any attention.
I'd agree with broken or incorrect seals during installation, but the shop I used only uses AC Delco, and I didn't have this problem until the other day, about 2 & a half years after installation. And actually the code may be P0452 or 458, I'll check again when I get in the car to make sure.
Old 03-22-2012, 06:22 PM
MakaveIi's Avatar
Turns out its actually p0405
Old 03-22-2012, 06:51 PM
In that case, follow the flow chart in this lnk: https://blazerforum.com/forum/diagno...plained-35147/
johnrerika
01-14-2013 10:41 AM
benshuey
06-19-2010 05:22 PM
trapperjohn4077
06-07-2010 10:49 AM
chrisblaze
05-23-2009 02:21 PM
mytruck2
12-13-2006 04:50 PM
Quick Reply: I can smell gas around the fuel pump
