P0452 - Help!
P0452 - Help!
So my blazer has been periodically throwing the P0452 code, more so lately than it has in the past 6 months. I want to track down this issue and get it taken care of. I think my evap readiness monitor wont complete because of it thus not allowing me to get my car inspected. (stupid emissions county in Texas).
From what I have found so far it seems to be a sensor on the fuel pump. Im going off of speculation here but I would think if that sensor is on its way out it, the SES light would be on constantly and not every so often.
Is there anything I can check without having to remove the tank to check the sensor?
Is there some sort of relay that I can check? or hose? Gas cap was purchased in the past 6 months or so when I initially started having the issue.
For those of you familiar with obd2 scan tools: I have a bluetooth obd2 scan tool with Torque and was wondering if there are any meters I can add that can assist with checking this.
Thanks and I appreciate any assistance!
Here is a link to the trouble code which will walk you through the process of trouble shooting the code from start to finish and should identify the problem:
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
As well as a link that will show you the threads where others have posted about this same code --> Search for "P0452"
