Which pins to jumper?
Old 01-24-2015, 04:41 PM
mlk1950's Avatar
mlk1950 is on a distinguished road
Default Which pins to jumper?
I have a 95 Blazer LT and was wanting to know which pins do I jumper to get codes.
Old 01-26-2015, 01:07 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Looks like you have an OBD 1.5 system. This thread may have some useful information for you:
https://blazerforum.com/forum/2nd-ge...n-codes-65927/
Old 01-26-2015, 07:08 AM
If your 1995 has a 16 pin connector, the vehicle is equipped with OBD1.5 and you can not jumper pins on OBD1.5 systems, (late production 1995). You must use a scan tool capable of communicating with your PCM. It requires a unique software in the scan tool.
Old 01-26-2015, 01:19 PM
mlk1950's Avatar
Thank you for the replies. I talked to the mechanic that I take my cars to when I can't figure it out myself, and he said the same thing. I need a scan tool for it. I have a scan tool, but it will only do 98 and later.
Old 01-26-2015, 01:36 PM
OBDII protocol was standardized in 1996, so if your scan tool works on 1998, it will communicate with 1996 & newer. The OBD1.5 was a mid year transition to OBDII. As a result, it requires special software to communicate with it.
phxjosh
19
06-03-2013 02:06 PM
nathaniel1988
30
01-23-2012 09:38 AM
manekDC2_
04-20-2010 11:51 AM
rastoma
10-07-2009 05:57 PM
ginobass
06-26-2007 02:39 PM
Quick Reply: Which pins to jumper?
