P1406 - Cleaning EGR passages in the intake??
Yes, I searched.
I changed the intake gaskets on my '97 this weekend. I got a P1406 code for the EGR pintle in the wrong position. It seems to run just fine, idles good, no ill symptoms other than the check engine light.
I didn't clean the EGR passages and didn't think anything of it I read some threads about spraying carbon cleaner in the hose going back to the exhaust. What can be done with the passage going to the intake? Can the EGR valve iteself be spray cleaned?
Any words of caution about cleaning these?
Not sure what you searched under, but there are many threads on this subject.
Regardless, you should not need to clean the passage to the intake as it really does not get dirty. The passage between the valve and the exhaust manifold is where the brunt of the buildup occurs due to how often the valve is actually shut and carbon deposits settle out.
Regular carbon cleaner can be used on both the valve and down in the port/tube from the exhaust. I use a large & long brass pipe cleaner to clean the port out. Then plug the port to the intake and start the engine to clear the debris from the supply line.
so what would be suitable for "plugging" the intake hole while starting?
i can just see myself standing there holding something... and then POOF... im covered in soot! lol. but seriously... what do you suggest?
EDIT: Wholy Old Threads batman... my bad!
ESKYMOPACK
01-21-2015 04:11 PM
MrTwister
01-15-2012 07:24 AM
96jimmyslt4x4
10-02-2011 05:37 PM
dustenwolff
05-27-2009 07:31 PM
