Engine ticking problem?
Hey guys. On my 1999 blazer 4dr 4wd. It has this Ticking noise coming from what I think is the engine.
It wont tick immediately when you first start it in the cold morning. But then within a minute or so of being started, the ticking will begin. But really only at idle.
When I am driving around on the streets it will run as normal, but when I let off of the gas, It begins to tick, and will continue to tick at the stop light.
I am going to try and get a video of it for you guys.
But Any ideas on what it could be?
Thanks!
Chad
Thanks!
Chad
You don't say how many miles??
Get under the hood and rev it up and see if the ticking comes and goes with the engine speed. I have seen timing chains stretch and hit the inside of the timing cover and it will sound just like a lifter. The chain kind of waves as the engine speeds up & slows down allowing the chain to hit the cover.
Put a stethescope on the valve covers. If you don't have one use a long screwdriver, extension, metal rod etc. Place one end on the valve cover and the other end on your ear. If it is a lifter it should be louder on one side.
It has 165,000 miles..
I am going to go get a video now of me reving under the engine. It will just take a while for me to upload it.
That timing chain could fit the description of the sound I am hearing.
Let me go get a video and upload it!
sounds almost like a rod knock because it still does it while the engine is backing down to idle.. but a wiped cam lobe can sound the same...listen at the oil pan and have someone rev it up a few times.
It is a little hard to tell the sound is consistent with a lifter or timing chain. The first thing I would do is listen to the valve covers like I suggested. If it is at the valve cover Rislone often helps if it is a sticking lifter. Other wise it could be anywhere in the valve train such as a bad rocker arm, rocker ball, broken push rod end or lifter/cam lobe issue. No additive will help any of these issues.
If you can't hear it at a valve cover take the serpentine belt off and see if you can touch the timing cover with the engine running to see if you can feel it hitting. It will be hitting on the pass side if I recall right. DON'T do this unless you are positive you won't get hurt from the cranksheft pulley.
If your engine has a nylon cam gear the teeth cam come off causing the chain to be loose and hit the cover in addition to 165,000 miles of stretch.
