Passlock
Passlock
Ok I've finally had it with my blazer and this stupid passlock. I've changed everything the pcm the bcm the ign switch the multifunction switch and I'm still having a no start situation once and a while with it. I've done the relearn thousands of times and it helps for a day. How the hell do I eliminate the passlock? Theres gotta be a way to eliminate it.
[quote=J_man01;462259]Ok I've finally had it with my blazer and this stupid passlock. I've changed everything the pcm the bcm the ign switch the multifunction switch and I'm still having a no start situation once and a while with it. I've done the relearn thousands of times and it helps for a day. How the hell do I eliminate the passlock? Theres gotta be a way to eliminate it.[/quote
What about the Passlock Sensor at the Key? It senses the turning of the key and sends the signal to the BCM. Sometimes the wiring (3-wires, Yel, Org/Blk, Red/Wht) gets damaged or the sensor fails.
Isnt that part of the ign switch?
Im getting no b codes The 3 wires were part if the ign switch the module is what the 3 wires plug into correct?
If you have decided you HAVE to have passlock disabled i believe PCM4Less will do it as part of a tune.... beyond that I'm not sure. But it CAN be done.
Replace lock cylinder and keys, I did that on our 02 impala and it works every time now
Just have to do the relearn long procedure.
This is not the ignition switch it's the key cylinder
I'm geting no bcodes ive got a scanner that will read them. I replaced the passlock sensor again it working fine for now so im getting rid of it before this crap happens again out of all the blazers and s-10 trucks ive owned this one by far has been the biggest POS. Thanks for all the help guys.
eknox327
25
12-13-2018 11:33 PM
knight1292
08-14-2008 09:30 AM
