2 problems need help with
i have 2 problems i need help fixing.
98 blazer, 4.3 v6, 3.73 ratio, 2 dr, 4x4, 127777 miles
problem 1) p0300 code (random misfire) i have changed coil, cap, roter, plugs, wires and fuel filter. it is still hitting, is there anything else that could cause it. i have done everything the guys at auto zone know to do. SES turns on around 60 mph, will turn off when going city speeds for a day or so. first hit day after put fuel sys cleaner in. been getting poor milage.
problem 2) 4 wd not working. made a lot of clicking sounds when it went out. transfer case locks in. (cant spin drive shaft when 4wd engaged, can when not engaged) something in front axle i figure. was interstate driving in 2wd when it went out.
This may help you with your misfire codes.
https://blazerforum.com/forum/diagnostic-trouble-codes-dtcs-49/p030x-explained-x%3D0-1-2-3-4-5-6-a-35153/
For your 4WD problem, check out this post, it gives a great run down of your problem and how to fix it and basically why it occurs
https://blazerforum.com/forum/tech-articles-diy-29/4x4-no-worky-maybe-will-help-7180/
Luke92S10Blazer
02-06-2010 04:24 PM
upblazer95
04-04-2009 08:27 PM
