PO341 And PO339 - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 04-18-2011, 02:11 PM
rickyota89 is on a distinguished road
Default P0341 And P0339
Hi guys this is my first post ive been having some trouble with my 97 4.3 5spd. 2dr blazer. The codes i keep geting are a p0341 and p0339 . I bought it needing work and got all other stuff fixed and still cant figure out whats goin on! I replaced both the cam and crank sensors. Does this mean i need a case/crank relearn done or should it be ok? its got a miss at around 2grand or so under lite pedal and sometimes even when really geting on it im stumped and the couple mechanics ive talked to dont know nothing about the case/crank relearn procedure.Ive done some searching on here and can't seem to answer my questions. Any help would be much appreciated!
Old 04-18-2011, 02:18 PM
rriddle3's Avatar
Have you read through both these threads?
P0339 Explained
P0341 Explained
Old 04-18-2011, 02:22 PM
P0339 - CKP (crankshaft position) Sensor Circuit Intermittent
P0341 - CMP (camshaft position) Sensor A Circuit Range/Performance
Take a look at the links above. See if you can find a common failure point between the two sensors. For instance, both sensors are grounded through the PCM. If the PCM were to loose its ground, the sensors may drop out. This condition can be quite intermittent. A scan tool with live data monitoring could be used to watch the sensors and see if there are any drop outs during operation.
I would also say that you should test the wiring from both sensors to the appropriate location on the PCM. The wiring diagrams in the links above are from a 2000 and the PCM used in 1997 is different. I'll see if I can find the appropriate diagram for your truck for PCM terminal references.
You can also search for the codes to see what others have come across if you haven't already. Just remember, that's a zero, not an 'O' after the 'P'.
Old 04-18-2011, 07:00 PM
Yeah i looked at them just wondering if there was anything that i was missing and wondering if the crank relearn was possibly my problem. Ill have to check the wires. i didnt know the 2000 pcm plug wires are different than my 97. If u could come up with that would help me out cause im not the best with wiring to begin with lol!
Old 04-18-2011, 09:16 PM
'96 & '97 are the same and here's what I had previously found:
Closed Thread
Thread Thread Starter Forum Replies Last Post
ses,abs,airbag,seatbelt,and battery light,and temp and gas gauges malfunction builder125 2nd Gen S-series (1995-2005) Tech 1 05-20-2013 07:51 PM
Starts ok,...but give it gas and she idles up and down and dies!! JetJock79 Engine & Transmission 11 12-31-2011 02:11 PM
Truck bogs and buks, and ABS and BRAKE lights come on!!! Ugly_Monkey 2nd Gen S-series (1995-2005) Tech 31 06-04-2010 04:06 PM
Tags
43, blazer, chevy, code, corvette, crank, ii, obd, p0339, p0341, po339, po341, procedure, relearn, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
