Power seat not working
Old 08-02-2007, 09:53 PM
KnowNothing's Avatar
KnowNothing is an unknown quantity at this point
Default Power seat not working
My 99 blazer 4 door 4x4 power driver seat has stopped working, at all. It was working on and off for a while and now it never works... very inconvienient. Im thinking that because it worked on and off for a while that its not the motor, and possibly a fuse somewhere. If anyone has any way to find the problem it would be appreciated.
Thanks,
JD
Old 08-06-2007, 09:45 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Power seat not working
Check the wiring under the seat, and by the switch. It is very common for the wires to break in these areas. If these areas are good, then check power and ground to the switch. If one of these are not present, then start tracing backwards, of course saying that you have checked the fuses in the fuse block. HTH.
LowLife
11-15-2010 09:15 PM
1996 Blazer Driver
09-29-2010 10:52 AM
LilMsChevy
01-11-2010 09:45 PM
Scooterewski
19
03-07-2009 03:50 PM
tommyd
05-06-2008 11:31 AM
Quick Reply: Power seat not working
