2002 Power window regulator installation
Old 03-06-2012, 10:01 AM
blanco36's Avatar
blanco36 is on a distinguished road
Default 2002 Power window regulator installation
How hard is it to install a new power window regulator? Any info on this matter will be greatly appreciated.
Old 03-07-2012, 12:35 AM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Actually it is fairly straight forward - remove the door panel and the factory rivets holding the defective part in - easy to drill out . Use bolts or new pop rivets if available to reinstall replacement regulator . Once You pull the door panel and door liner moisture barrier it will all be revealed .... how are the door lock actuators working ? ...... since You have it open anyway ? My '95 driver's side needs both
Old 07-30-2012, 07:56 AM
Echeban's Avatar
Echeban is on a distinguished road
Default window stuck down, how do I get it up?
My driver window is stuck down. I removed the panel and moist barrier. When I apply 12.5 DCV to the motor directly, it does not move, but takes current and makes a typical little noise of a motor taking current. Reverse the polarity and does the same. I was going to order a new regulator but my Haynes manual says that I must have the window all the way up before drilling out the rivets. How do I get it up?
comandoed
08-25-2013 10:03 PM
jimhens82
10-21-2012 06:37 PM
my 88
05-16-2010 05:36 PM
degaine_designs
08-10-2009 03:55 PM
rhs856
07-28-2009 10:34 PM
Quick Reply: 2002 Power window regulator installation
