Radiator flush 97 blazer - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 12-09-2010, 03:56 PM
Looee is on a distinguished road
Default Radiator flush 97 blazer
I need to flush the radiator on my 97 blazer. I'm guessing there should be 1 or 2 plugs that need to be removed to drain the fluid but I can't see where they are. There is a metal plate right below the radiator that has the door to get to the oil filter. Do I need to remove that plate to get to the radiator drain plugs?
Old 12-09-2010, 04:05 PM
The drain plug on the radiator is located just below the lower radiator hose on the passenger side of the radiator. It is a pain to get to and many people just pop off the lower hose.
Old 12-09-2010, 04:10 PM
terry s is on a distinguished road
If you wish to do a complete job and flush/drain the block there is a drain plug on both sides of the engine just above where the oil pan meets the block. They are usually pretty tight so a 6-point socket is a must. If you have 4wd the one on the driver's side is next to impossible to get to.
Closed Thread
Thread Thread Starter Forum Replies Last Post
To flush or not to flush hroofblaze96 2nd Gen S-series (1995-2005) Tech 5 12-27-2012 08:33 AM
Aftermarket bumpers - flush and non flush, trim pfsantos 1st Gen S-series (1983-1994) Tech 3 09-23-2010 04:58 PM
Whats a good brand radiator flush or radiator cleaner to use? bigdaddykane93 2nd Gen S-series (1995-2005) Tech 6 01-04-2010 01:03 PM
coolant flush with flush kit portcqb 2nd Gen S-series (1995-2005) Tech 2 04-29-2008 10:56 AM
Power Steering Flush & Brake Flush ? ZR 2 2nd Gen S-series (1995-2005) Tech 2 12-04-2007 04:53 AM
Tags
97, 98, blazer, chevy, coolant, drain, engine, flush, flushing, hose, location, lower, plug, radiator, radiators
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
