random misfire please help!!! - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-19-2006, 10:04 PM
jdblazer is an unknown quantity at this point
Default random misfire please help!!!
my 2002 chevy blazer has 73000 miles on it when i go to start it when cold or hot it takes about 6 seconds or sometimes two trys to start then has a very small miss in it only when idleing or giving very little gas.the service engine lightis on and computerreads random misfire. i have gave it a full tune up plus replaced the fuel filter ignition coil andcolent temp sensor also had the fuel pressure regulator checked psi is 70 im low on moneyto keep buying new stuff.i have heard it might be the throttle pressure sensor but i dunnothanks ahead of time.oh i also bought it like this thinking it would be a easy fix so any ideas are very appreciated.
Old 12-20-2006, 01:13 AM
Default RE: random misfire please help!!!
Dirty MAF sensor, carboned up EGR or IAC. Might be a dirty poppet valve sticking....try running Seafoam through tank, it might unstick the poppet valve, depending on the amount of carbon...
These items can be checked and fixed with a minimum of money...seafoam= $8-10. EGR cleaning cost of gasket, same for IAC cost of TB gasket if the old gasket becomes damaged...
Old 12-20-2006, 12:58 PM
Chevy Lover is a jewel in the roughChevy Lover is a jewel in the roughChevy Lover is a jewel in the rough
Could you post the code# for your missfire?
Closed Thread
Thread Thread Starter Forum Replies Last Post
random misfire wtf??? please someone help blazerhelp01 Engine & Transmission 15 03-30-2015 09:36 PM
PLEASE HELP!!! 99 4.3 random misfire codes, rides really rough kdawg1354 2nd Gen S-series (1995-2005) Tech 5 02-26-2013 09:55 PM
p0300 and p1380 random misfire need help! shanegreen 2nd Gen S-series (1995-2005) Tech 9 04-22-2012 10:25 AM
Help-p0300 random cylinder misfire hunterman18 2nd Gen S-series (1995-2005) Tech 13 06-22-2010 07:55 AM
Help! P0300 Random/Multiple Misfire b_didddy510 2nd Gen S-series (1995-2005) Tech 1 05-28-2010 05:10 PM
Tags
1999, 2000, 2002, 43l, blazer, chevy, complete, fire, grand, honda, misfire, miss, odyssey, random, tuneup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
