2000 Blazer - Idle only
Old 09-02-2011, 02:11 PM
gpeebles's Avatar
gpeebles is on a distinguished road
Default 2000 Blazer - Idle only
try to make long story short - Blazer overheated, cracked head! Got a used head, machine shop magnafluxed, valve job, seals, surfaced. Replaced all hoses, plugs, wires, cap&rotor. Ran good for 2 days, maybe 20 miles total. Drove today, little longer distance, died at idle. barely made it home, now the engine dies with any accelerator! Off idle, dies, With every 4-5 attempt, I can rev it over 2K rpms, it will keep running, but dies, as soon as you reduce rpm. I checked EGR valve-working fine, not that dirty, checked fuel pressure, looked fine (replaced pump and regulator about 4 months ago). Appreciate any ideas!!
Old 09-02-2011, 02:31 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
what did the fuel pressure read at key on,and after 10 min of holding pressure?
Old 09-02-2011, 02:48 PM
gpeebles's Avatar
fuel pressure sat at 55 psi in off position, 65 cranking
Old 09-02-2011, 03:06 PM
pettyfog's Avatar
Guess we need the codes read then
Old 09-02-2011, 03:17 PM
gpeebles's Avatar
452 and 453, I had these occasionally before
JohninVa
10-12-2014 06:23 PM
jeffr_ca
07-19-2010 10:25 AM
bassgrinder
03-30-2007 03:30 AM
Benado
10-02-2006 11:41 AM
Quick Reply: 2000 Blazer - Idle only
