And the mess continues
Old 09-02-2011, 07:17 AM
coolasice's Avatar
coolasice will become famous soon enough
Default And the mess continues
Well, picked up all the parts to fix the blaze yesterday and started in early, got the diff fluid out, axles out, changed bearings and seals, in the process regreased the park brake assemblies (one was completely frozen), replaced backing plates which are NOT what holds the park brake, the park brake is attached to the bracket that holds the disc brake caliper... changed the U-joint (what a bitch that was)... then as I was finishing putting the drive shaft back on I noticed something broken... a leaf spring at the bushing in the front... damnit, and I thought I was gonna be all set for winter after this.... Gonna have to go back to the yard and find some leafs now... what a pisser so my question,
are all 4wd 4door leafs the same? are some stiffer then others?
z06maniac
23
06-03-2011 09:42 PM
Thor_449
04-23-2009 04:47 PM
ARTMANIII
12-13-2007 09:05 PM
joey
01-24-2007 01:58 PM
Blazer1965
03-25-2005 12:34 PM
Quick Reply: And the mess continues
