re: P0410
Old 08-21-2008, 08:31 PM
ZR 2's Avatar
ZR 2 is an unknown quantity at this point
Default re: P0410
Hi there, I read the what the code explanation is in the DIY section but does anyone have any step by step instructions how to replace the air pump, hose & air check valve....how diffilcult is it to replace the relay if that is the part thats broken? Gonna check to see if the fuse has popped tomorrow and the relay this weekend...any info. will be appreciated
2001 ZR2 Blazer
thanks
Old 08-22-2008, 08:27 AM
Default RE: re: P0410
As far as replacing the relay, just pull it out and push the new one in.
The pump is located under the radiator. If you take a look at it, it is fairly straight forward as far as removal. The intake tube should be clamped to the side of the fan shroud on the passenger side about half way up. I have posted pictures of how it looks in at least one other thread.
AKYooper
12-27-2013 01:51 PM
steve
11-04-2008 07:02 PM
steveinmd
01-09-2008 10:03 PM
BlazinJay84
12-13-2007 09:38 PM
flyinbrad
Engine & Internal
01-08-2007 11:40 AM
Quick Reply: re: P0410
