transmission/electrical nightmare
okay so i got a 95 ls 4 door 4x4 blazer. i had tranny rebuilt becus of no 3/4 shift put it in top off tranny it reads good but still no 3/4 shift. put new tps, prndl switch but still no help i hooked to snapon scanner no codes at all and can shift 3/4 with scanner but computer wont do it on its own. so i got 2 pcms from bone yard but still no help starting to think its in the harness or a bad ground but not sure... if any one can help please all info is appreciated searched all kinds of threads and post cant find any that will help with my problem.. thank you for your time. also it is a 4l60e
Ok , read your post wrong. Could be your 3/4 shift selenoid. Yuo would have to drop your tran oil pan and theres 2 solenoids, one is 1/2 and the other is the 3/4/ they are both the same part I believe just not sure which one is the 3/4. Online search will probably help
If they work from the scan tool, they should work from the PCM. Might be an intermittent or poor connection though. Check the electrical connector on the passenger side of the transmission. Make sure all of the terminals are tight in the harness connector, and that the harness connector is fully engaged with the transmission connector.
