wheel bearing replacement questions
Old 11-23-2011, 08:54 PM
retwizted's Avatar
retwizted is an unknown quantity at this point
Default wheel bearing replacement questions
sorry wasn't sure where to post this. hey guys i searched the forum and found nothing about this that was good enouph. i have to replace the passenger side wheel bearing. how hard is it? how do i do it? and do i need to buy the hub assy or can just buy the wheel bearing itself? doing myself.2000 blazer 4wd 4dr blazer.
Old 11-23-2011, 08:58 PM
Must have missed the Tech Article section:
4wd Hub/Bearing Assembly Replacement
You cannot replace just the bearings in the unitized hub/bearing assembly. The rest is covered in the post above. The difficulty of the job depends on what you have available to you in terms of tools as well as experience. I have it down to under 30 minutes to swap a unitized front hub on pretty much any GM vehicle. Having an air impact, air chisel, and a good 3-jaw puller (in case the splined CV shaft doesn't want to release from the bearing assembly) make things go a lot faster.
Old 11-23-2011, 09:01 PM
retwizted's Avatar
ok thank you i forgot to look in the sections for help
davedidit
12-27-2011 12:20 PM
tibby
10-02-2011 11:37 PM
mikeinwi
24
05-29-2009 12:04 PM
skoot
01-23-2007 05:17 AM
Chavez96
09-20-2006 04:04 PM
Quick Reply: wheel bearing replacement questions
