Under-body rust gone wild
Old 05-09-2010, 05:50 PM
shligger's Avatar
shligger is on a distinguished road
Default Under-body rust gone wild
I've owned my '96 Blazer for half a year now. The truck is clean on the outside and inside with select spots of rust near the wheel wells. The problem is the under-body rust. I replaced the front brake pads with the aid of a friend last month and it took us about a half hour to break each nut. I want to clean the under-body and make it look nice again.
My spare wheel looks like it was cast in rust. I didn't take any photos of the under-body (with good reason) but I do have an exterior photo I took when I first got it.
Old 05-09-2010, 06:13 PM
wlorton's Avatar
Get some decent jack stands.... and lift her up and blast all the bad stuff away... and then hit it with some undercoating/paint.... do it proper means only doing it once.... but I had the same thing.... I hit it with some sanding, and then dropped some paint.... looks darn good... especially when you sit it next to someone else's vehicle...
Old 05-09-2010, 06:21 PM
shligger's Avatar
So what kind of tools are required for the job? How do you the protect under-body wiring from tools?
Old 05-09-2010, 07:22 PM
wlorton's Avatar
Well.... the tools that are must need would be:
jack
Jack stands
Sand paper/grinder/sander depending on how much rust....
Hose/power washer.... to clean before primer/paint/undercoating
Choice of paint/primer/undercoating
That should be it
Old 05-10-2010, 10:04 AM
shligger's Avatar
So what do you undercoat it with and it what order? Do you just use a normal car body primer and paint or is there a special undercoating I can buy at my local parts store? Thanks for all the help.
Blue thunder 2000
Tires and Wheels
09-23-2012 05:39 PM
atvwarrior
07-20-2012 03:53 PM
tibby
05-26-2012 09:26 PM
shovelhead
10-09-2011 09:50 PM
jochumson
10-18-2010 02:15 PM
Quick Reply: Under-body rust gone wild
