rear windshield wiper washer fluid - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-01-2007, 02:51 PM
carlo is an unknown quantity at this point
Default rear windshield wiper washer fluid
i have a 95 blazer and in it there is a switch to turn on the rear winshield wiper and then if u hold it down the rear windshield wiper fluid should come out to clean the window. the fluid is not coming out and i have no idea where it is supposed to be coming out from. i filled my washer fluid to the top and still it doesnt work. does anyone know what the problem is? thanks
Old 01-01-2007, 02:56 PM
Default RE: rear windshield wiper washer fluid
It is possible that the pump for the rear wiper has failed. The pump is located in the washer fluid bottle alittle higher than the pump for the front wipers. You should hear a pump up front turn on when the button is pushed. Have someone in the truck with the key just in the 'ON' position turn on the rear wipers and hit the button. If you hear the pump, then you either have a restriction in the line or a disconnected line somewhere between the pump and the rear wiper. If you don't hear the pump, then either the pump is shot or you aren't getting power to the pump either due to a broken wire or a faulty switch.
Old 01-01-2007, 03:03 PM
MNHawk is an unknown quantity at this point
I liked it better when there was a front and rear container. Less hose to replace if it goes bad. Not to mention how its routed.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Rear windshield washer fluid and defroster joshua_andrew92 1st Gen S-series (1983-1994) Tech 2 03-18-2010 03:01 PM
Rear Windshield Washer fluid Dripping... Matty Kling 2nd Gen S-series (1995-2005) Tech 2 10-10-2007 01:25 PM
rear windshield washer fluid jboy76 General Tech Help 3 06-07-2006 09:25 PM
Windshield washer fluid pump kaindragoon36 2nd Gen S-series (1995-2005) Tech 4 03-25-2006 04:22 PM
Windshield Washer Fluid leaking inside drivers side floor..please help fruccoman General Tech Help 1 02-15-2006 07:08 PM
Tags
1996, blazer, bottle, chevrolet, chevy, fluid, hose, location, operate, pump, rear, washer, windshield, winshield, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
