rear wiper tank?
rear wiper tank?
Is there a seperate wiper fluid tank for the rear windshield on my 2001 Blazer?
RE: rear wiper tank?
Nope, no additional or separate tank. Just a separate pump in the tank. The rear pump is positioned higher than the front pump to prioritize the front when the level gets low. The pumps themselves are the same so if you are having trouble, you could swap pumps or just lines to the pumps and see if that'll fix it.
Hi
I can not find any lines from pump to rear washer mounted to tank. I can see only pump with connection to windshield washers. But I can hear motor of rear washer and front washer too. Where should I seek the lines to rear pane?
Marcin
Marcin
ORIGINAL: Marcin
Hi
Marcin
Hi
Marcin
Thank you for help.
Marcin
Marcin
Helter80
06-14-2013 08:34 PM
wjdjake
07-17-2011 02:06 AM
pusher_sr
03-06-2005 04:26 AM
