Remove steering wheel or not?
Old 12-17-2010, 05:47 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Remove steering wheel or not?
Getting ready to replace the ignition switch. Found a few proceedures on doing this. Question I have is some say remove steering wheel, some don't mention removing it at all. Could someone please clear this up for me? Is it necessary or not, Thanks.
Old 12-17-2010, 06:12 PM
The sound insulator and knee bolster along with both of the column covers need to be removed. Removing the steering wheel makes it a little easier to see what you're doing, but it's not necessary. If you do remove it, be very careful of the clock spring, it is expensive. When the wheel is removed, DO NOT turn the steering shaft.
Old 12-17-2010, 06:47 PM
gmbwrenchn's Avatar
Where is or please discribe the the sound insulator and knee bolster.
Old 12-17-2010, 06:50 PM
Sound insulator is black plastic panel above brake pedal, (has the OBDII connector attached to it). Knee bolster is the panel just below the steering column.
Old 12-17-2010, 06:58 PM
gmbwrenchn's Avatar
Ok thanks. Have you ever had to replace the ignition switch in a 97? If so, any tips would be appreciated, Thanks.
Old 12-17-2010, 07:18 PM
There's "How-to" thread here some place, but I can't find it, maybe someone else knows where it is.
litterbug
10-19-2011 07:50 AM
caseroj
10-20-2010 08:10 AM
Cavalier z24
09-03-2009 08:20 PM
fou99
12-24-2008 12:35 PM
Smoked
07-25-2008 07:31 PM
Quick Reply: Remove steering wheel or not?
