Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Gen S-series (1995-2005) Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Blazer Forum!
Welcome to Blazer Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Blazer Forum today!
Closed Thread
LinkBack Thread Tools Search this Thread
Old 08-04-2007, 10:27 AM
Megalodon_Al is an unknown quantity at this point
Default Removing parking brake handle
I hope this isn't too dumb a question! I need to install the brake controller for towing my trailer. In order to do this I need to get under the dash and at the wiring to the the brake at the pedal.. The emergency brake release handle has no obvious way of being secured to the shaft, ie: set screw. So how do I remove it without breaking something in the process?
Thanks for your help.
__________________
'99 Blazer 4x4 4dr Auto
'05 Monte Carlo SS Supercharged
K & N Cold Air Intake
Flowmaster Super 40s
Old 08-06-2007, 02:43 PM
Ted Ted is offline
Ted is an unknown quantity at this point
Default RE: Removing parking brake handle
Not vehicle specific, as I don't know yours, but:
I'm not sure you want to remove it from the "shaft" (usually a cable). What makes you think you want to? Removing the bracket that holds it in place may make it free swinging to allow access to wahtever you're trying to get to.
Old 08-06-2007, 09:40 PM
The handle is attached to a hexagonal shaft, not cable, which goes through a small opening in the cover. The cover protects the underside of the dash. I guess I could remove the screws and let it hang but it will be very awkward to work under there with the cover taking up so much space. There is no way to remove the bracket as that is under the cover also.
__________________
Old 08-06-2007, 11:04 PM
2000 Chevrolet Blazer
viper4559 is an unknown quantity at this point
Get behind the dash and follow the cable, there will be a point where you can unhook it allowing you to take the dash piece and brake lever out. I think it was around 8"-12" of cable before the connection. Just stick your head under there with a flashlight and you should see what I am talking about.
__________________
2000 Blazer LT 4 Door 4x4
Old 08-07-2007, 10:05 AM
Thanks for your help Viper. I will check it out.
__________________
Closed Thread
Tags
2000, 99, blazer, brake, chevy, cjevy, emergency, handle, lever, parking, release, remove, removing, replace, unhooking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
