4wd hi/lo work fine no 2wd
Old 04-22-2013, 10:32 PM
00chevy's Avatar
00chevy is on a distinguished road
Default 4wd hi/lo work fine no 2wd
Hey guys found out this morning my blazer is stuck in 4wd. Well last night I was using 4wd hi and forgot to put it back into 2hi before bed. Well this morning I left for work it was in 4wd hi and I tried to change it to 2wd and it didn't do anything and still wont do anything im lost. it is a 3 button switch and it will go into 4wd lo and back to 4wd hi just fine but no go on the 2wd. Someone please help. Thanks Ryan
Old 04-23-2013, 07:38 PM
00chevy's Avatar
no one on here can help I see that other people have had this issue but no one updates to say how they fixed it
Old 04-23-2013, 11:11 PM
BMWDr's Avatar
BMWDr is on a distinguished road
Mine did the same thing. I took the switch apart and cleaned the contacts. There is a thin metal strip that goes over a middle contact. when you press the button it closes the connection momentarily. I de-soldered mine but could have probably been done with 1000 grit sand paper. Of course the switch is only $30 or so but I like seeing how things work! Good luck.
atvwarrior
07-01-2013 05:14 PM
lowloudnproud1
09-02-2010 07:12 PM
LYK2ROC
12-05-2008 07:08 PM
gERgMan
05-16-2008 10:12 AM
Mikes1Addiction
01-12-2007 02:08 PM
Quick Reply: 4wd hi/lo work fine no 2wd
