s10 2.2l mass air flow sensor - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 03-14-2007, 01:28 AM
speeddemon560 is an unknown quantity at this point
Default s10 2.2l mass air flow sensor
Hello. Does it make a difference if I use a ported mass air flow sensor that come off a 2.2l S10 on a 2000 4.3l blazer? Thank.
Old 03-14-2007, 02:34 AM
Default RE: s10 2.2l mass air flow sensor
It can because the computer is expecting to see a specific amount of airflow and the 2.2L MAF might not have the flow needed to keep the computer happy...also connectors might be different....
Old 03-14-2007, 10:11 AM
When it comes to MAF sensors, you have to make sure that their frequency response is the same given an equal flow rate of air across the flow range the 4.3L requires.
1st thing I'd check is to see if the MAF sensor is even the same size as the 4.3L MAF. The 4.3L MAF is the same one used on the 5.7L v8. Are you replacing it in hopes of gaining performance?
Old 03-14-2007, 10:42 PM
Kordog is an unknown quantity at this point
The 2.2l does not use a MAF sensor, it uses a MAP sensor that senses pressure in the intake, where the MAF measures the air flow into the motor. The 4.3l uses both sensors.
Old 03-14-2007, 10:44 PM
Quote:
ORIGINAL: Kordog
Whoa. You just blew my mind. Thanks for the help.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Mass Air Flow Sensor puckrocker 2nd Gen S-series (1995-2005) Tech 2 07-12-2011 11:29 PM
Mass air flow sensor-2002 blazer 2k2Blazer Engine & Transmission 6 10-26-2009 05:20 PM
Mass Air Flow Sensor truesmack 2nd Gen S-series (1995-2005) Tech 9 08-09-2009 09:51 PM
aftermarket mass air flow sensor O_P_PLaya Headers, Intake, & Exhaust 10 09-02-2007 02:22 PM
Tags
1999, 2001, 22, air, airflow, chevy, flow, location, maf, map, mass, problems, replacing, s10, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
