Serpentine Belt 1996 s10 Blazer
Old 11-10-2009, 01:46 PM
Bob_55's Avatar
Bob_55 is on a distinguished road
Default Serpentine Belt 1996 s10 Blazer
Hello all. I have a 1996 s10 4wd 4.3L Blazer with 186,500k miles(free-way miles) & just replaced the original ball joints over the weekend with help from this forum(thanks everyone). Also replaced the original starter, not an easy starter to replace.
My A/C compressor is just about shot & i don't want it locking up on me somewhere. Can i use a serpentine belt from a non-A/C blazer to by-pass the compressor altogether? Looks like a wide range of belts for this vehicle.
Old 11-10-2009, 02:19 PM
rriddle3's Avatar
I would replace the a/c compressor with a pulley of the same diameter and run a belt for a system with a/c.
Old 11-10-2009, 02:34 PM
Bob_55's Avatar
Smile
Thanks rriddle3. I found a company that sells by-pass pulleys for a reasonable price. Don't even use the a/c up here in the northern midwest. Would love to have 2 heater cores though! brrrrrrrr. Here is a link for anyone else that's considering this route.
http://www.partspros.com/a-c-bypass-pulleys.html
Old 11-27-2009, 09:25 AM
Bob_55's Avatar
Update. I ended up buying a non-a/c serpentine belt & a non-a/c idler pulley. The idler pulley(6 groove) sits right below the a/c compressor. The threaded hole for the pulley was already there. I didn't disconnect a thing. Now all i have to do is switch drive belts for a/c.
This saved me a few hundred for now. Might replace the a/c in the summer or just leave it, but hope this helps someone else with a similar issue. Only problem was the idler pulley. Most auto part stores only carry the pulley. You will need to find a COMPLETE pulley(pulley,spacer,bolt,dustcover). Found mine on ebay for $20(new).......Cheers!
Old 06-11-2012, 05:26 AM
Mully98's Avatar
Mully98 is on a distinguished road
BoB 55 is quite right. I by passed my ac unit the same way. I went to the junk yard and pulled off a idler pulley for the bolts to put on the new idler pulley. 20min job.
Old 10-29-2015, 10:43 AM
Ryan02Stang's Avatar
Ryan02Stang is on a distinguished road
Anyone know the part number for the non-AC idler pulley?
Stephen Uhlenkamp
03-19-2012 10:28 AM
ooohtodd
04-03-2007 09:27 PM
cimbali
03-25-2007 03:29 PM
Quick Reply: Serpentine Belt 1996 s10 Blazer
