SES Code P0452
Old 06-14-2012, 11:27 AM
O-man21's Avatar
O-man21 is on a distinguished road
Default SES Code P0452
O'Reilly had a ton of possible causes listed, how do I go about fixing this?
Truck still drives fine.
Old 06-14-2012, 12:33 PM
Here is a link to the trouble code which will walk you through the process of trouble shooting the code from start to finish and should identify the problem:
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
As well as a link that will show you the threads where others have posted about this same code --> Search for "P0452"
Old 06-14-2012, 01:56 PM
O-man21's Avatar
Thanks for those. I read them over and looked through the search results, and honestly, a lot of it went over my head. I am pretty mechanically inclined but I have limited access to tools and only know the location of major parts in an engine bay.
Is there a common problem that causes this code? Or since I don't have many tools, should I just break down and take it somewhere to fix?
Also, is this something that needs to be fixed ASAP? I'm starting a new job next Wednesday, and moving between now and then, so if I could use the truck until after then it would be awesome.
Thanks!
Old 06-14-2012, 07:32 PM
O-man21's Avatar
driving around today, light went off for about 2 hours. Turned it on after a brief stop and it came back on. Any reason that would happen?
PogiMoto
12-15-2012 12:03 AM
rwbean1991
07-18-2012 09:32 PM
ve3nsv
01-04-2011 07:15 PM
pigmak
09-27-2009 09:56 PM
kup125
09-10-2006 09:50 PM
Quick Reply: SES Code P0452
