starting prob fuel pump/regulator?? 97 Blazer
Ok here's the issue again 97 Blazer V6 2wd 93,000 miles
Having trouble starting themotor is trying to start. Sometimes will start other time a shot of ether will do the trick. Can hear the fuel pump run than the relay clicks themotor just cranks, this is usually the case in the morning, but not necessarilytoday startedafter "priming the fuel about 3 times. Normally will start the rest of the day. Have changed the fuel filter, was filthy. I have had no issues while driving no hesitation or bogging. Is this the fuel pump or the fuel regulator that is at fault?
Thanks in advance for any input!
RE: starting prob fuel pump/regulator?? 97 Blazer
Thanks, see where that leads will let you know
Terje
11-04-2017 08:19 AM
LSpoweredStepside
09-30-2013 09:22 PM
mcanter23
09-05-2010 09:36 PM
heitger0003
04-17-2007 03:33 PM
jlinder
08-21-2005 11:08 AM
