2001 starting problem
2001 blazer : if sits overnight takes a shot of ether to start. After that will start if cranked over 2 times and release key. Only starts when key is released back to on position.
The key problem makes me believe your starter is weak, buddy of mine's blazer had the same issue and it continued to get worse until it wouldn't start we had to replace the starter last week.
I suggest you do the 96+ Fuel system diagnoses located in the DIY tech articles section of this forum,. Your fuel pump could be getting weak and what you describe is a common symptom.
whats a fuel pump on these things go for? i have the same issue minus the ether.
im getting sick of putting parts into this moneypit... i should just buy winter tires for my other car and call it a day.
impalla350
04-21-2012 05:19 PM
Stablock
05-16-2011 12:38 PM
lukewb
14
12-02-2006 02:23 AM
mickey2001
03-13-2006 11:51 AM
