Temperature gauge not working - Blazer Forum - Chevy Blazer Forums
Reply
Thread Tools Search this Thread
Old 01-14-2010, 04:51 PM
2005Jimmy is on a distinguished road
Default Temperature gauge not working
2005 Jimmy - temp guage stopped working the other day. Still getting good heat to cab (winter). Probably some open wiring somewhere. Can anyone tell me where the sensor is on the engine (near thermostat?) so I can start tracing back to firewall?
Thx.
Old 01-14-2010, 08:24 PM
awe341 is on a distinguished road
The temperature sensor itself may no longer be working. It is located near the thermostat on most engines and is cheap to replace.
Old 01-14-2010, 08:37 PM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
For your year 05 it will be located on the drivers side cylinder head between the back 2 spark plugs, on earlier years like my 97 there was also one by the thermostat but that was for the pcm and not for the gauge, on your 05 there should not be one by the thermostat as that was eliminated as the one in the cylinder head is now used for the pcm and the gauge
Old 02-12-2010, 01:39 PM
Thanks, appreciate the response.
Old 02-12-2010, 01:40 PM
Thanks Nvidia78, will check it out.
2005Jimmy
Old 02-12-2010, 04:35 PM
terry s is on a distinguished road
You can see if the gauge is working by taking the wire off the sending unit and connect it to ground with a jumoer wire. Then don't start it but turn the ingition switch on. If the gauge starts moving up the gauge should be ok. Only do this long enough to see if the gauge moves do not leave the switch on for very long.
Assuming the wire is not broken or disconnected it may just need a new sending unit.
Reply
Thread Thread Starter Forum Replies Last Post
Temperature Gauge Stopped Working slowsinglecam Lighting & Electrical 0 06-26-2012 09:42 PM
Temperature gauge reads extremely hot, car not actually overheating? LVUSC14 2nd Gen S-series (1995-2005) Tech 4 05-24-2012 02:11 AM
help...temperature gauge not working after intake gasket replacement billfrank85 2nd Gen S-series (1995-2005) Tech 9 04-17-2012 09:25 PM
Speedometer, Temperature Sensor, Fuel, Not working tscott 2nd Gen S-series (1995-2005) Tech 8 10-11-2011 02:56 PM
Temperature Guage Not Working jacko623 2nd Gen S-series (1995-2005) Tech 0 12-14-2009 01:40 PM
Tags
1992, 2000, 2001, 97, blazer, chevy, cutlass, engine, gauge, inop, s10, supreme, temp, temperature, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
