timing change - set timing?
Ok I replaced the timing chain set on my 95 today. I probably ought to check the ignition timing? or is this one of those that sets itself? If i need to do it with a timing light, is there a wire i should disconnect first? Thanks !!
not 100% about s10s. but i recently picked up a 90 fullsize with a tbi and theres a sticker under the hood that tells you in detail exactly how to check the timing and which wire to disconnect and where to find it
OK i checked the sticker " says to disconnect the timing plug".....but it doesn't show any diagram of where that is.........there are two connections to the distributor??is it one of those? ANy help is appreciated. Thanks pat
so should i look up under the dash? pull the carpet back on the passenger side? anybody got a picture of it? the eng runs great right now, but i just pulled the distributor and put it back based on my paint marks.....pat
do you think the timing connector is labled? i've got the factory repair manual, but when i look up changing the timing it says to llook in another book.......something like the emmissions and driveablilty manual or something like that.........
well i pulled the carpet back about 6 inches and didn't see any connectors.....maybe they moved it to a better spot? there's two plugs into the back of the distributor..........not one of those? i wish i had that "other" factory manual!!
