Trans Fluid cooler lines secure ?
Old 07-16-2014, 05:24 PM
cferry7's Avatar
cferry7 is on a distinguished road
Default Trans Fluid cooler lines secure ?
1995 Gmc Jimmy SLT 4wd
What tool can be used with success to tighten / loosen the Trans Fluid Cooler Line connections at the transmission end.
This is a very tight spot - high up on the transmission underbelly on right side of transmission.
12 mm or 13 mm Flare Nut, I believe.
I believe one time when I had the trans separate from the engine via the bellhousing bolts removed, that lowering or raising the trans byway of a jack/plywood under trans pan - made access to these two upper cooler line flare nuts much easier.
However, their should be another tool/method when engine/trans are completely mated ???
suggestions . . . .
Old 07-29-2014, 04:17 PM
cferry7's Avatar
Default resubmit
Any suggestions ...... ?
Old 07-29-2014, 06:05 PM
Tranzman's Avatar
Tranzman is on a distinguished road
This is what I use... a 3/8" drive 1/2 or 13mm (whichever is tighter) crows-foot from snap-on(flank-drive) with a 1" extension, impact swivel and a long swivel extension(length depends on situation) attached to my 3/8" swivel headed Ratchet.
Tranzman
Old 07-30-2014, 09:01 AM
cferry7's Avatar
Tranzman
wow ! That is great ! Thank you
shotnva777
09-22-2011 07:41 PM
fondo
Headers, Intake, & Exhaust
10-28-2008 08:58 PM
johnsonmopar
10-23-2007 02:23 PM
95blazer8620
04-06-2007 04:16 PM
Jetfixer
07-11-2006 05:02 AM
Quick Reply: Trans Fluid cooler lines secure ?
