Vaccum Ball Question 96 can you use a ...
Old 03-06-2008, 03:54 PM
muleman's Avatar
muleman is an unknown quantity at this point
Default Vaccum Ball Question 96 can you use a ...
OK so i was replacing my vaccum lines and went to pull the live off of the vaccum ball and the nipple of the ball came off with the hose, so i was going to drill it out and jsut silicone it in the ball.. then i thought i would go to the nearest salvage yard to see if i could find one... Well no luck, question is i found one off a 93 s10 it is a bigger ball, it works but will it hurt anything? or is the ball size not going to casue me any problems, thanks.....
mine 96 zr2
donor 93 jimmy.
Old 03-06-2008, 03:59 PM
Default RE: Vaccum Ball Question 96 can you use a ...
It is just a reservior to store up engine vacuum. Think of it as an air compressor tank. The larger size, if it fits, will have no impact on its performance in a negative way.
Old 03-06-2008, 04:22 PM
muleman's Avatar
OK thanks i jsut might find a way to mount this one and save me a little money..
Bolbol
18
06-10-2015 02:18 PM
Doctorvette
11-05-2012 11:57 PM
brendan127
12-11-2011 10:08 PM
cochran07
03-07-2011 04:36 PM
warlock3055
03-16-2010 05:33 AM
Quick Reply: Vaccum Ball Question 96 can you use a ...
